i believe intel is more reliable..Why Intel CPU only? AMD's new 3000 CPUs are cracking quality and pound to performance.
had one pc years ago with amd cpu, it didnt last that long.. i guess its also just could be me having intel based pc for a very long time.. but you know what am gonna try an amd cpuOn the basis of what? That's absolute rubbish
AMD and Intel both make great CPU's. But right now AMD will give you more for your money.
That aside, no idea where reliability comes into it tbh. Never heard of CPUs just 'dying'...
got Acer XB271HUA 27 g syncWhat is the make/model of your monitor?
Do you have plans to stream?
Your budget would accommodate a 9700K build (wouldn't be my choice) but Ryzen is the best all round performance choice, and for your budget you could be sat on a 3700X coupled with a decent warranty 2070 super (@Sparx - demonstrates what you get for the bottom end of your budget well - the 3600 being a mighty bang for buck CPU).
No, a quality 650W is fine - the Seasonic Focus is £10 more but comes with a 10 year warranty. And 16Gb is plenty for gaming - you would be better served putting the extra ~£85 towards the 3700X (8c/16t).i think i will go with sparx build but dont i need a bit more power than 650w? maybe 750w?
and id still be lift with some money so spend on memory?
