first Gaming pc build
4 Jan 2012
Hi, looking to build my first rig after Xmas and new at this would just like if you could check all the part's i have picked out are all good and compatible and if you could recommend a mobo, psu and case, would be looking to spend no more then 200£ to 250£ on them all together. thank's
Intel CPU Core i5 3570K Quad Core IvyBridge
XFX 7850 Black Edition DD AMD/ATI Graphics Card - 2GB
Cooler Master Hyper 212
Toshiba/Hitachi DT01ACA100 1 TB (7K1000.D) SATA III - 6Gb/s Hard Drive 7200rpm - HDD
8GB (2x4GB) Corsair DDR3 Vengeance Military Green, PC3-12800 (1600),
Ok forget the small budget was thinking of the Cooler Master CM-690 II Advanced USB3.0 Windowed Dominator Case - Black and Asus P8Z68-V PRO GEN3 Intel Z68 mobo but still not sure on the psu..and would like to add a ssd at a later date..
Hi, can i just ask what the gaming Performance will be like with the XFX 7850 Black Edition DD AMD/ATI Graphics Card - 2GB and if i can get better for the money..or should I good for the XFX 7950 3GB Black DD Edition
