I have this system
first of all i dont think i set it up correctly to start with as it has been a bit slugish on games
I have a got this screen shot
sorry to big to post so hers a link
and this is my bios settings
CPU operating speed: user Defined
External clock 220MHZ
Mulitplier factor : 10 x
DRam Speed (CPU
RAM) : Default (ddr2-800) - options are 1:1.00
1:1.20
1:1.25
1:1.50
1:1.66
1:2.00
Pci Express frequency 100mhz
Voltage control: maual
cpu core voltage 1.3250v
ddr2 Voltage 2.20v
cpu VTT voltage 1.2000v
Ich 1.50 V Voltage 1.50 v
MCH 1.25 V Voltage 1.250 v
CPU GTLREF 63.0%
I dont know if any of thats correct but should i just keep increasing the external clock?
What temperature should i be looking at keping it under
Thanks in advance
n00b
Code:
Gainward BLISS GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) -
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) -
Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
Antec NSK 6580 Super Midi Tower Case - 430W Earth Watts PSU
OCZ 2GB (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series
artic cooling freezer 7
DRam Speed (CPU
RAM) : Default (ddr2-800) - options are 1:1.001:1.20
1:1.25
1:1.50
1:1.66
1:2.00
ddr2 Voltage 2.20v
CPU GTLREF 63.0%
Thanks in advance
n00b
