Just trying to work out the voltage thing, sorry.
I just had a quick read regards VID and Vcore, but not 100% sure of the difference between the 2?
Run CPU-Z now and voltage is 1.176v on Prime95. VID is 1.246v
I used a how to guide for the OC and it didn't state setting a specifc voltage in the BIOS, just fixed or offset - which I used and the offset which I set as +0.005v, this was what was suggested in the guide.
Looking at the two voltages above apparently the offset is the difference between the V-core and VID? So should I set this to +0.07?
