First i7 build spec check
18 Feb 2009
Hi,
Making a computer for my bro's birthday. Could someone be kind enough to check and see if I made any mistakes/forgotten anything?
The function will be gaming, but I also have to try and make it as cheap as possible.
Thanks a lot in advance.
Plenty of reviews saying that a i7 is no better than an i5 for gaming (toms hardware).
So you could save £60 on the CPU and because you aint going to be using crossfire you could use a p55 motherboard for the i5, and you can pick one of those up for £90 saving £40. You would then need just 4gb ram (Dual channel rather than tri channel) saving £20.
You could also just buy a cheap gaming case for £30 and save another £60.
Also if you aren't going to overclock the factory supplied cooler would probably do saving another £25.
That's roughly £200 saved, and i'd use it to get a SSD to host you operating system and games as they will load a lot faster and generally seem like a much faster machine.
+1 to this bit
Id disagree with this though
Thats true
Personally I wouldnt, and Id of thought if youre on a budget you wouldnt want to really either, but your call, if you did have the money to spend and dint want to keep hold of it, Id look at one of ATIs new 58 series of cards which will have greater impact on gaming
Things Id change slightly are HDD, either a samsung F3 or Western Digital Caviar Black, PSU if youre thinking about possibly adding a 2nd card in future, up it to circa 7-750W, monitor, Id try and squeeze in the Samsung 24" T240
Thanks for everyone's replies, really helped me out.
This is what I have at the moment:
I have a question about the graphics card. 5850 looks neat, but does anyone know when it will be released? And also I've been trying to find some benchmark tests for it, but was unsuccessful so far. Does anyone have a link? Really I have to order everything and essemble by the 10th of October, so it might not be an option for me to wait until 5850 comes out.
The 5850 is already out, its just out of stock at the moment. Most seem to be arriving back in stock on the 2nd of October, while others will be back on the 9th.
The 5850 is a good chunk faster than the GTX 275. Here is review which shows both. You should also bear in mind that the 5850 is a DirectX 11 card, so it will full support future DX11 games, while the GTX 275 only supports up to DX10.
On another note, I would give the Dell monitor I specified a good look, unless you are set on the samsung. The dell uses a far superior eIPS panel which gives much better viewing angles and image quality, also it is backed up by dell's "Premium Panel Guarantee" and a next working day replacement programme.
This is worth a lot as well. This means that Dell will replace your screen if you have any dead pixels on arrival. Some monitor companies have a minimum dead pixel threshold where if you have less than 'X' dead pixels they won't replace it.
Dell will replace for as few as 1 dead pixel. RMA with OCUK was fast too - well worth buying Dell for the service you get
This is a little over budget but it will ruin most games.
The XFX 5850 has 2 year warranty through OcUK hence why i chose it
The gd80 is an expensive motherboard and you could save 50-60 by buying a cheaper mobo, but the fact that pressing 1 button on the OC genie on the Mobo will put the 750 to 3.4ghz stable and its receiving excellent reviews.
The samsung f3 is a very fast drive and I beleive the 500gb version is single platter since the 1tb is dual platter.
Modular PSU to remove unwanted cables
The 5850 is not out, no-one has one yet. OCUK say is 2 days or so, while other sites are saying 1-2 weeks.
Hopefully be proved wrong as i want one and am waiting for stock and proper reviews before i commit to a whole system.
