First ITX Build : Zotac Atom N330 Dual
18 Oct 2002
Cambridge, UK
Hi,
Well I thought I'd put together a new HCPC so I went for:-
Hardware
Zotac ION Motherboard with Intel Atom N330 Dual Core Wi-Fi Mini-ITX Motherboard ( with 90w PSU )
Western Digital 2TB Hard Drive SATA300 7200rpm 32MB Cache
Silverstone SST LC03 Black (Was gathering dust in the cupboard)
2 x Crucial Ballistix 2GB (2x1GB) (Had these lying about)
Software
Vista Ultimate x32
WifiRemote (Allows you to control Media Center from Iphone)
Wake on Oui (Allows you to wake up a sleeping PC with a Magic Packet from Iphone)
I plan to retire my Popcorn Hour A-110.
Cheers
HEADRAT
Pretty much what I'm going for apart from a smaller case, tv card and a Xbox 360 as a media extender instead of hooking the Atom straight up to the TV. I've got a similar setup at the moment using an aging SD11G5 and it can no longer cope with VMC :(
Are these boards good enough to play 1080p video very tempted to get one for downstairs...?
Agree that they are fine using hw acceleration (nvidia purevideo) which is fully supported by the 9300/9400.
Something I have found though is that if you need subtitles (e.g. for foreign language films), you *won't* be able to use the "purevideo" GPU acceleration. Purevideo relies on having a direct path from codec to display and any additional rendering filters placed between will result in fallback to software decoding. So for example, the directvobsub.dll filter will cause this problem.
The easy solution is to use the latest CoreAVC codec, which uses CUDA acceleration instead (shader acceleration). It only uses a little more CPU than the purevideo route doing it this way (still well within the capabilities of an atom I would think), and it allows for additional filters to be used.
Btw, if I'm wrong about any of this, please correct me. It's based on my findings with the Zotac 9300-ITX board, XP pro, and Media Player Classic - Home Cinema. :)
