First laptop wondering what's best
13 Oct 2013
Wants
Play AAA games on low settings
17inch screen
Back-light keyboard
Ryzan cpu
Cost under £850
And that's about it really just looking for a decent enough laptop to be able to play AAA games on low settings obviously higher settings would be a bonus but I don't have a mega amount of money to spend and I realise top end laptops aren't cheap.
£800-£850 to spend
I'm pretty clueless on laptops to be honest so I need your help please
17" screen is the expensive bit of your requirements.
Otherwise, any Ryzen 5 laptop will game AAA at low settings. Would cost about £450.
Here's an example video of a laptop Ryzen 5, with integrated graphics, gaming:
Would this be a good option I know its not AMD but it does have a dedicated gpu which may be better then what a 3500u or higher can offer
https://www.cyberpowersystem.co.uk/...lNSkLjIu6-i8NMUqFl0xAbBmiiOKsZyIaAulbEALw_wcB
I didn't realise a 3500u alone. Would be able to play AAA I thought I'd need a gpu in there of sorts
I'm happy to drop the 17inch if I could hook it. Upto my 55inch TV or 27inch monitor without causing issues and still be able to play...... What do you think wouldn't want the laptop to be smaller then 15inch Tbh
