** FIRST LED BASED DDR4 IS HERE & MORE RAIDEN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Those who love the LED based RAM from Avexir will be very happy to hear they have now released Red Core series with Red Strobe LED effect in DDR4 2666MHz at a great price:
Avexir Core Red Series 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (AVD4U26661504G-4CIR) - Red Light @ £199.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Core Red Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 15-15-15-35
- Dual Channel Kit: (4x4GB)
- 100% tested at 2666MHz in Intel X99 based motherboards
- Lifetime Warranty
Only £199.99 inc VAT.
ORDER NOW
Avexir Core Red Series 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (AVD4U26661508G-4CIR) - Red Light @ £379.99 inc VAT
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
Features:
- Black PCB
- Dual Channel Kit: (4x8GB)
- Lifetime Warranty
Only £379.99 inc VAT.
ORDER NOW
Avexir Raiden 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (AVD3U21330904G-2RD) @ £99.95 inc VAT
AVEXIR AVD3U21330904G-2RD Raiden Series 8GB Kit (4GB x 2) dual channel 240-pin DDR3 2133MHz 9-11-10-27 DIMM desktop memory module.
Raiden series is, a high performance DDR3 / DDR4 gaming memory modules, using world exclusive patented technology of plasma tubes to mimic lightening effect for gamers who seek true stimulation and real excitement, also proves the product making philosophy of AVEXIR once again: "What we believe is how we behave.
These high quality memory modules are built for your confidence which passed 16 hand picked AIST (Avexir Ic Sorting Technology) processes and 14 memory module functional, burn in, and compatibility tests for Intel chipset 7, 8, and 9 series motherboards. AVEXIR built top level specification of Raiden series by using 10 layers performance optimized design printed circuit board and industrial grade resistors and capacitors. It is also featuring Intel XMP technology, you could easily setup Raiden series memory modules to rated speed with zero hassle factor.
JEDEC Standard : DDR3-1600K CL11-11-11-28 1.5v
XMP : DDR3-2133 CL9-11-10-27 1.65v
Features:
- Exclusive patented technology of plasma tubes to mimic lightening effect
- 8 layers performance optimized design printed circuit board
- Exquisite packaging
- Support XMP
- Hand picked AIST(AVEXIR IC Sorting Technology)
- Golden Finger Protector
Features:
- Black PCB
- White high performance heatspreaders
- Blue Plasma Strobe lightning effect (See product images)>
- SPD programmed at: JEDEC standard 11-11-11-28 values at 1600MHz.
- CAS Timings: 9-11-10-27
- Dual Channel Kit: (2x4GB)
- 100% tested at 2133MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £99.95 inc VAT.
ORDER NOW
Avexir Raiden 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (AVD3U21330904G-4RD) @ £191.99 inc VAT
AVEXIR AVD3U21330904G-4RD Raiden Series 16GB Kit (4GB x 4) dual channel 240-pin DDR3 2133MHz 9-11-10-27 DIMM desktop memory module.
Features:
- Support XMP
Features:
- Black PCB
- Lifetime Warranty
Only £191.99 inc VAT.
ORDER NOW
Avexir Raiden 16GB (2x8GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (AVD3U21330908G-2RD) @ £158.99 inc VAT
AVEXIR AVD3U21330908G-2RD Raiden Series 16GB Kit (8GB x 2) dual channel 240-pin DDR3 2133MHz 9-11-10-27 DIMM desktop memory module.
Features:
- Support XMP
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Only £158.99 inc VAT.
ORDER NOW
Avexir Raiden 32GB (4x8GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (AVD3U21330908G-4RD) @ £329.99 inc VAT
AVEXIR AVD3U21330908G-4RD Raiden Series 32GB Kit (8GB x 4) dual channel 240-pin DDR3 2133MHz 9-11-10-27 DIMM desktop memory module.
Features:
- Support XMP
Features:
- Black PCB
- Lifetime Warranty
Only £329.99 inc VAT.
ORDER NOW
Great memory from Avexir. :)
