Never thought i'd even consider watercooling, but the noise of the multiple fans in my current desktop is getting to me, and i'm thinking of watercooling it to make it quieter,
Thinking of those sealed systems where you get the radiator, pump, pipes and the block all nicely sealed, i've seen them on youtube videos. and the radiator just seems to slide in the top of the case... so i presume a new case will be needed (i have my brothers 'antek' case from 2012 (i think it's a 902).. i can't see any hardware that a watercooler rad would slide into... but that case does have a 200mm fan at the top which would be nice to utilise if possible)
I am running an I5 2500K processor at 4.5 gig overclock, ... it runs the one simulator game i run on this computer perfectly, but can i even get a watercooler for such an old processor?
I also have a GTX 1060 that i'd like to watercool as well if i can do so easilly,
Will wanting to watercool 2 items mean i cant use those all in one sealed solutions? or could i run 2 of them... or am i better off building a custom system that will use one large radiator and cool both the cpu and gpu on the same circuit?
i have no interest in flashy lights, glowing water tubes etc, i just want a quieter system.
