- 18 Feb 2013
Hi!
I was looking for a little advice, hopefully, someone here will be happy to give some guidance.
Im going to set up my first loop. I picked up a Thermaltake pacific 360m kit. I'm also going to add in a GPU block.
Can someone please let me know what additional fittings I will need?
The kit comes with:
2 x pacific G1/4 90 Degree Adapters
8 x Pacific C-Pro G1/4 PETG Tube 16mm OD Compression Fitting.
V-Tubler PETG Tube 5/8” (16mm) OD 500mm (4 Pack)
The kit comes with hard tubing, I'm guess I will need a heat gun. Would it be better to get some 90-degree adapter?
Also as this is my first setup, would it be better to go with soft tubing? or order in some extra hard tubing, in case anything goes wrong.
Thanks!
The kit comes with:
Thanks!
