Guys I've had this rig for about a year now and I'm ready for some OC'ing...
I've read the stickies and guides (from this site and others) and I've had a good go. I started by increasing the CPU ratio from 16 to 17 then 18, at 18 it was unstable so buttoned it back to 17.5. Then I increased the CPU BUS frequency from 200 to 205 and then 210.
I've got it to 3.69GHz.
It runs prime95 on blend for an hour, reaching a max temp of 64C. Is this safe enough? Within Coretemp I have set the Overheat protection tab to shut down after 60secs at 64C. I remember reading somewhere this was about right but I'm open to suggestions...
I'm pretty sure I can get more out of it with some expert help from you guys.
See photos of my Bios Setup.
I know that leaving so many options on Auto is far from ideal but, frankly I don't understand what to alter or what order to alter it and whether the values need to go up or down!
Please give me some simple instructions as to what to alter, in what order and how to do it. I've included the photos because part of my problem is that there seems to be about 20 different names for the same thing - which confuses me, so if you can use the same definitions as are in my BIOS I would be grateful.
Thanks
Shane
PS RAM is DDR3 PC3-10600 (1333MHz)
Thanks
Shane
