First bash at OCing on a shiny new E6600 on a DS3P with a Noctua HSF and Geil PC6400 RAM.  After reading all the stickies and the DS3 owner's thread the results are:
- Disabled all the stuff in the BIOS the owner's thread says should be off.
- Upped RAM Volts to +0.3 (=2.1V) and changed timings to 4-4-4-12 as per instructions.
- Changed divider to 1:1
- Changed FSB to 400 and multiplier to 7 = 2.8GHz on CPU, 800mhz DDR on RAM
- Left everything else (volts, PCIE etc) at stock / auto. Gigabyte EasyTune reports CPU volts at 1.33 but then again it reckons my CPU idles at 13 (yes, THIRTEEN) degrees.
- Idle temps circa 30/30 by TAT
- Load temps after 25mins Orthos 44/45 with no errors.
- Knocked 2-3 seconds off SuperPi 1M
Please can someone with a bit more experience check this and make sure I've not missed something or done something stupid. I'm tempted to try 400x8 = 3.2Ghz but that may be too far and I'm still wrapping my head round how to get the RAM at proper speed with an FSB that doesn't divide in easily.
Also, what happens if you leave SpeedStep and SmartFan on with the CPU OC'd - does it fry or fail to boot?
TIA.
TIA.
