first OC temps seem high ?
23 Aug 2007
Hay guys my try at overclocking a cpu and this what i did so far
FSB from 200 to 240
cpu clock Multiplier x10
Memory multiplier from auto to 2.0
system voltage control (manual) was on auto but temps went to 60c :confused:
and turn off the other stuff like CIA2
This what i got so far
spec are
Dual core 2180 stock cooler
x2 1 gig OCZ DDR2 PC2-6400 / 800MHz / ATI CrossFire™ Certified Edition / Dual Channel
Motherboard Gigabyte GA-p31-ds3l
Case is mozart TX
I don't know if i am doing some thing wrong as i never done this before bin getting help from another forum so all that stuff i did is not on my own by any means lol :D
What temps do you get at stock with the same test?
It might be fine and just the stock cooler and the airflow inside your case.
Ok i did the same test i set the FBS back to 200
Bit lower but nothing major :(
I don't get it i have mozart tx case should be good cooling going on :confused:
I did sort mod another fan above the cpu pushing air up maybe that fan messing up the air flow ?
Thanks
have you the volts running at 1.325? Do they need to be that high?
I had my E6400 running auto with 1.325 and dropped the voltages down to 1.2 and shaved 10°C off my temps. (You'd need to check with intel if this can be done with your CPU though?
Yeah i know but thats the normal setting it was on i not change that at all yet so not sure.
yeah I will start looking for the info about that
Thanks
They're ok considering it's stock cooler, your case temp aint best and I guess you didnt use MX-2 there either. And dont believe in what some say that those chips will hit 3.2ghz on stock cooling, yeh, maybe they will but not with any kind if safe temps ;). Or if you got very lucky and that 1 per 10 000 best chip. The truth is simple - you wanna OC high - get good cooling.
Now there is room for improvement:
TRUE -10c
MX-2 4-8c
better airflow/case temp -5c
TRUE -10c
MX-2 4-8c
Yeah i will get better cooler soon as :D
Just thinking if the volts need to be that high as jas72 already said ?
Also would worth taking off the cooler and putting bk to make sure its on ok ? i don't have any thermal paste but the cpu only few days old ?
Cheers
Buy some thermal paste and a new cooler. then you'll obviously get to reseat the new cooler and should help :)
56ºC at full load not that hight tbh. These chips are safe up to 73ºC according to intel so as long as ** under this keep going. Use CPUz to see your actual vcore.
Cpuz says core voltage at 1.312V
I try and up the fbs past 240 see what temps go like
I just got a feeling maybe the heatsink not on right :(
