First order from Overclockers.. How long does it usually take?
Tried a few games of Fortnite. It feels a bit sluggish to me. I definitely need to up the controller sensitivity maybe that will help. Would OC have made sure the BIOS is setup for optimised gaming?
you can check whether expo is enabled. what do you mean by sluggish...what settings/res are you playing at and what fps/latency are you getting? I take it you have the adrenaline software downloaded and can enable that to show as an overlay. My son always thought fortnite was janky on pc. it can be prone to microstutters etc. he preferred play that on xsx
Played Fortnite with Adrenalin installed. That reported 105.5 fps, when the game first started with Adrenalin there was some rippling effect but I think performance improved, does that software auto tune?
no, but the textures load into the vram of the gpu etc, so once in there, game shouldn't need to reload them etc so gameplay should improve..one reason you want a card with more vram...8gb cards when run out of vram start slowing down and loosing textures in game
It offered me Adrenaline but I didn't know what that was. I will install it.
Adrenaline is the AMD software that controls everything..haven't actually looked in awhileon mine..maybe if set to auto it might change settings to run better...there should be a performance tab on there somewhere (sorry at work atm)..you can also undervolt gpu while giving it more power and also change the memory clocks...eek out some more performance, if you like doing that...while away the time altering setting and then doing something like timespy to see how performance changes
They are very busy as I get free next day delivery and it's changed to 3-5days due to Xmas.
I wouldn't fall for that sob story.
I've bought twice this week from a competitor, and they've delivered next day DPD, both times, one of which was today.
Along with every RM parcel arriving on time.
Thanks I’m embarrassed to say I think I did something stupid but have recovered it and it’s working well now. I will watch tha video, cheers
Think most of us have done stupid things in the past, it's how we learn.
If you are still having issues with your games try disabling these in Windows.
Settings>Gaming>Game Bar.
Settings>Gaming>Game Mode.
