First Overclock- Advice
20 Aug 2007
E6400
3Gb Ram- Corsair value select
Asus P5B Vanilla
Sythe Ninja cooling
Did a first O/C at 2.8 ghz and it looked OK according to the Site I used so bumped it to 3.0Ghz
Temps seem quite high but after some googling, it might be ok
any advice?
does this o/c look ok?
2.8 was at about 50 degrees C idle, 62 under load
this is 54 idle, 65 load (speedfan shows 70 under main cpu temps but the individuals are about 65 per core.
Are the RAM timings OK?
i've give it a Wobble, and it seems secure but it did take few goes to get "in there"
the temps have always seemed a bit high but a few P5B standard review have said the board gives high readings...??
Those temperature look very high for an E6750 under a Ninja, even with a moderate overclock on. I would have expected Core Temperatures in the high 40's at idle. Are you using a fan on the cooler?
yes, fan is on
my stock fan was idle at about 36 with no O/C
the ninja only dropped by about 1-2 degrees
i've read somewhere that the pop pins on ninja aren't v good so some people are using a screw bracket. can't remember where i saw it tho!
