Been reading up on overclocking for a while now and finally thought I'd give it ago. Managed to get it up to 2.2Ghz from 2.0Ghz.
Running 166 divider with multi of 10. I'm on standard HSF but should be getting Scythe Ninja Plus sometime this week.
I've ran Prime for about 1 hour just to see CPU temp under load. Was around 40 - 42ºC. Also wanted to know what sort of torture tests I should be running on Prime, not quite sure? I know I should be running Prime for at least 24 hours anyway. Should I have my command rate on 1T also?
Don't be fooled by the MB tool also. I've done all my OC'ing in the BIOS. Only reason I have that is to match the volts and temps with CPUZ and Speedfan
