First overclock to keep.
18 Feb 2007
Wirral
today i finally finished my new build getting the memory, altho its only standard crucial memory PC 5300 667MHz, ive got my CPU to 2.8GHz, 800MHz on memory. i will soon be getting an antec 900 case and a tuniq tower, then ill try to get higher. also what speeds have people got on stock cooling and what temps you getting?
Getting around 40 idle 60 load with Tuniq Tower on a 6300 at 1.28 volts, but that said my room is insanely hot, back in winter it was around 10-20degrees cooler than this.
if you want a 900 give me a shout as mine will be on sale as soon as im allowed to use members makket as im going water cooled and maybe pelting... my overclock in sig uses the antec 900
