9 Aug 2008 at 22:48 #1 jas72 jas72 Soldato Joined 31 Jul 2006 Posts 10,277 Location Belgium land of chocolate popped my OC cherry. [img=http://img56.imageshack.us/img56/2205/99471093lz7.th.jpg]
9 Aug 2008 at 23:27 #2 MiNxYyY MiNxYyY Permabanned Joined 22 Mar 2008 Posts 3,977 Location Redditch jas72 said: popped my OC cherry. Click to expand... i Lol'd at that 2.5???466 x 9 FT wW
10 Aug 2008 at 10:53 #3 El Jimben El Jimben Soldato Joined 24 Jul 2006 Posts 3,323 Location Essex You should run small FFTs instead of blend to test CPU stability.
11 Aug 2008 at 10:58 #4 jas72 jas72 Soldato OP Joined 31 Jul 2006 Posts 10,277 Location Belgium land of chocolate I upped it to 333 so my ram is running at 667 (rated speed) on 1:1 divider So far the temps haven't went above 50 running prime and everything is stable. 3DMark06 went from 9500 to 11660 with the overclock so I'm well happy. I'll run a small FFT tonight to test stability tonight. I've read these things can go over 3GHZ (mine is currently at 2.7 with stock cooler). My mem is rated 667 is it possible to keep increasing the FSB and take my mem to 800? Or would that start involving increases in voltage? Currently I have my CPU on 1.2v.
