Sorry for the essay, ended up a longer post than I had planned.
Hello all, thought I'd join this fourm here, only found it the other day but it seems helpful. So the boring part -
My system spec. Im running a (in a Mini-Tower MicroAtx Chassis)
Phenom 9950 (125W) processor at 2.6Ghz ( for those who can remember that far back lol )
M2n68-vm Motherboard (v0805 BIOS)
4GB 800MHz Dual Channel DDR2 SDRAM - (2x 2GB)
500GB Serial ATA Hard Drive with 16MB Buffer
HIS IceQ 5670 1GB
corsair vx550 PSU
Apart from the Graphics card and VX550 the rest was bought in 2009 as as whole from the website Mesh, Quite a good deal when I bought it, to be honset for my usase I didnt need the graphics card but I wanted it and got it finally last year for christmas. Any-ways, eventually as everyone here does, I got the itch to overclock my desktop. Now I tried it before and did some researh but it never really workd out. Now I'm using a stock cooler and am not looking to do anything massive just yet, just the basic tweak to get into it (which is kind of useful considering my limited bios)
I've tried O.C. my CPU, atm I've got it at 2724 ( just changed the bus from 200 to 210 and kept multiplier at x13 ), when running occt it runs stable ( unlike when I was tried upping the multiplier on its own my pc kept crashing ) however it does run hot (around 65+ degrees)
so I stopped the stress test ( as in my general usage of the rig the temperature stays around 57 degrees - up from 54 from what it was previous, obv. I'm limited with a stock cooler and a small case limiting air flow but I think its usable at this stage).
Now I'm not 100% on overclocking my graphics card, so around 3 days ago I decided to let AMD's Catalyst Control Center to auto clock my card, left in the car and came back say 15 mins later and my TV screen was black - I assume it had gone into standby, but although my pc was on
there was no response from the keyboard, pulled the plug on my desktop ( did this a few times ) to cut a long story short it turned out that everytime my pc loaded as loaded the CCC on start up my screen would go blank, so I booted
into safe mode and stopped it from running at startup, then reinstalled it later.
After this I left O.C. my GPU for a bit.....okay 2 days, then tried it again, the auto overclock finally settled at the settings -
Coreclock raised from 775 - 840 Mhz
Memoryclock raised from 1000 - 1040 Mhz.
I've done some tests using 3D Vantage and got the following results:
Test 1 Test 2 Test 3 Test 4
Score P5732 P6075 P6009 P6135
C.p.u. Score 8214 8061 8015 8809
Graphics 5207 5614 5546 5571
Jane Nash 15 FPS 16 FPS 16 FPS 16 FPS
New Calico 15 FPS 16 FPS 16 FPS 16 FPS
AI Test 1041 1028 1014 1118
Physics Test 13 12 13 14
Test 1 was everything at standard settings
Test 2 Had the graphics at 840 Core/c and 1000 Mem/c
Test 3 Had the graphics at 840 Core/c and 1040 Mem/c
Test 4 Had the Cpu at 2.72 Ghz and the graphics at the setting in test 3.
Thats basically all I've done, nothing drastic however in the tests 1-3 my C.P.U was at its stock value and theres a 200 point value drop in its score, is the due to the graphics being overclocked impacting on it or is it just the C.P.U score fluctuating?
Thanks for reading, If anyone has any suggestions on getting a bit more out of my system I'll gladly accept it ( Doubtful though eps. seeing as it appears the first gen. phenoms are bad overclockers lol )
HIS IceQ 5670 1GB
corsair vx550 PSU
