Hello
I just finished building my first computer yesterday and Im very pleased with how it went, today I thought id have a look at the overclocking options that came with my Asrock Extreme 4 Gen 3 board. I just did a 1 hour test with prime95 and these are the results I got.
System spec:
i7 2600k @ 4.6Ghz
Asrock Extreme4 Gen3
8Gb corsair XMS3 9-9-9-25 1600Mhz
Crucial 128GB m4
ax1200 psu
evga 480's
ft02
venomous x black cou cooler with 2x akasa apache fans
Vcore Minimum - 1.040
Vcore Maximum - 1.360
Temperatures
Core 0 Min 25 / Max 62
Core 1 Min 30 / Max 70
Core 2 Min 28 / Max 69
Core 3 Min 28 / Max 69
Just wondering if these voltages and temps are within the safe range, and if theres anything else I could change to improve on these results (Not looking to go any higher on the overclock just maybe get temps down). I just used the 'automatic' overclock feature thatthe asrock board came with and have not touched any other settings yet.
Also on a side note during the tests core 0 was usually 8/10 degrees cooler than core 1 and core's 2 and 3 somewhere in between, any reason for such a big difference?
Thanks
System spec:
i7 2600k @ 4.6Ghz
Crucial 128GB m4
ax1200 psu
evga 480's
ft02
Temperatures
Thanks
