Not o/c Q6600, memory, fsb or changed bios yet, just completed build, cooling, XP install & tweaks & stability tests at stock, SATA config as AHCI
Found stable o/c on GTX using 169.21 WHQL drivers, used Rivatuner to config a 60% and 100% fan profiles + several o/c profiles, also used Core Temp
Initially system idle on GPU 60% fan and Tuniq fan lowest :-
GPU core = 54
GPU ambient = 39
CPU = 33 all cores
System idle on GPU 100% fan and Tuniq fan highest :-
GPU core = 50
GPU ambient = 35
CPU = 31 all cores
For synthetic benchmarks left GPU fan 100% and Tuniq on max
Max GPU core = 60
Max GPU ambient = 43
Max CPU = 37 all cores
Results below for 3DMark2001, 05 and 06 - also underclocked the OC2 to reference GTX clocks, then ran OC2 stock and then changed individual clocks before finishing with all clocks increased
GPU Clocks 2001 05 06 (ie 3DMark2001, 3DMark05 and 3DMark06)
Ref 575/1350/1800 44473 15072 11922
OC2 621/1450/2000 45435 15212 12172
OC2 621/1674/2000 46196 15167 12238
OC2 648/1450/2000 46017 15494 12045
OC2 621/1450/2052 45631 15192 12090
OC2 648/1674/2052 46076 15157 12279
Will be interesting if the o/c has a larger effect once I've got the Q6600 running circa 3.5GHz rather than stock
GPU core = 54
GPU ambient = 39
CPU = 33 all cores
GPU core = 50
GPU ambient = 35
CPU = 31 all cores
Max GPU core = 60
