first pc build check spec
With that hexcore CPU you won't need to go bulldozer. Therefore the AM3+ board is a big waste of money.
I would also lean to Intel sandybridge if I were to build now.
What is the resolution you are aiming for and screen size. Also you will need an OS
Ive always been involved with amd circles so intel is new to me.
Is this the Intel chip your on about RJC?
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN&groupid=701&catid=6&subcat=1275
what chipset do i need? and what motherboard would you suggest if i can keep the same spec or would i have to change anything else?
skylineboy
all the monitors im looking at seem to have 1920x1080 resolution with a screen size of 24-27" and forgot to say i have an os thanks.
fowler
I saw the bundle but liked the white case more and also the software that comes with the antec khuler
Thanks
Thanks mate I want a board that will last. Can you tell me if i can run 2 of these in crossfire on this board at 16x/16x? I've looked but cant find the answer.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-274-SP&groupid=701&catid=56&subcat=1752
Will they both run on this board with them being 2gb
Thanks
the asrosk that rjc suggested only does x8/x8 but from what I've read it doesn't make a huge difference, if you want x16/x16 you need a mb that the nf200 controller(need to check specs. they will both run fine, it doesn't matter if they're 1gb, 2gb, 3gb etc.
this defo does(tho if you get it beware the free fingerprint ;) ), others like the asus maximus extreme4 etc all in the £200+ price range.
Thanks I did like the look of the extreme7 board and that's one more reason. There's not many videos out there at the minute though, would be nice to see an unboxing. I dont mind paying extra as long as it will last me.
The corsair ram i chose was CL8
