First PC build - gaming under £900
13 Jun 2013
Hi guys,
I'm looking at building my first PC - will be used primarily for gaming and uni work. I've considered buying a pre-built but I can't get one for less than £1k so I'm biting the bullet and looking at doing it myself!
This is the spec I've put together at the moment:
CPU: Intel Core i5-4670 3.4GHz Quad-Core Processor
Motherboard: Gigabyte GA-Z87-D3HP ATX LGA1150 Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 660 2GB Video Card
Case: Cooler Master Force 500 ATX Mid Tower Case
Power Supply: Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply
Optical Drive: Lite-On iHOS104-06 Blu-Ray/DVD/CD Drive
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Monitor: Hannspree HL229DPB 21.5" Monitor
Keyboard: Logitech EX 100 Cordless Desktop Wireless Standard Keyboard w/Optical Mouse
This is coming in at £885 - any suggestions on substitutions etc? I need all the peripherals and OS too. I'd like it last me a few years at least! My maximum budget is £900, but the lower the better!
Cheers :)
Great, thanks very much - got all that priced up at £963.81 with my mouse and keyboard. Anything you could think to skimp on a little to shave it down to the £900 mark? Thanks very much for your help!
Drop the mechanical hard drive for now and buy one later, or not upto you. Should get you closer to budget.
Edit: Wouldn't bother with a wireless keyboard/mouse either. Get wired, less bother.
Double edit: You can officially and legally download windows and use it for a trial period of a month, after which it will prompt you to buy. In this time you could try both windows 8 and 7 and see what you want before buying either.
No need to spend money on an OS right away.
Sorry for the double post; I've been paid now, so have £900 to buy all my kit with - any alternative builds to bring me into this price? Thanks!
Getting the windows 8 dev edition (if it's still available) will pull you back into budget..
I think it's a 3 month free trail..
I wouldn't sacrfice your PC performance...
You could alway run another OS for a bit. :)
So that's what I've bought! With shopping around and deals etc., I've got it for £925, which will do :) Will I be alright with a stock CPU cooler with this spec? Thanks for all of your help!
