- 17 Jun 2011
- Surrey
This is my first PC build, and as the title says, I'm on a tight budget. My 9 year old custom built Alienware finally packed up, and as I no longer have that sort of money, I'm doing the opposite - getting as much as I can for as little as I can! As you can see, I've been gaming on a 9 year old PC so this new one doesn't need to be cutting edge, and seeing as the last 5-6 years have produced some great games that I've still to play, I'm happy that they'll keep me busy before I have to think about upgrading or building again. At which I hope to have more disposable income available...
OK so I've been reading the many threads on here, and reviews of some components and came up with this:
ASRock G41C-GS (ATX, Intel X4500 accelerator, DDR2/DDR3, up to 8GB RAM)
Kingston 2GB (1x2GB) DDR2 PC2-6400C5 800MHz 5-5-5-15
Intel Pentium Dual-Core E6700 "LGA775 Core 2" 3.20GHz (1066FSB)
XFX ATI Radeon HD 5570 1024MB DDR2 PCI-Express
Samsung SpinPoint F1 750GB SATA-II 32MB Cache
I have a new OCZ 500W PSU that I was hoping would fix my Alienware problem (it didn't!), so I'm hoping this will be enough. Unfortunately this lot came to around £215 so I had to make some compromises and came up with this:
Intel Celeron Dual Core E3500 "LGA775" 2.70GHz (800FSB)
MSI ATI Radeon HD 5450 1024MB GDDR3 PCI-Express
And this is for £175. I need to know if the 500W PSU is enough, if these are compatible and if this is good enough to play games over the last 5-6 years, not necessarily at the highest settings, but not on the lowest either! I already have a 22" LCD monitor at 1920x1080 screen res which I'd like to continue with, and it uses the 15-pin connector only. As the Alienware case is a beast, I'm keeping and using that too
And I'll be very glad to improve on the 2 USB ports! This will be mainly used for gaming, or maintaining my website, but seeing as I did that easily for years on the Alienware that won't be a problem for this one.
Now obviously I've taken a hit performance-wise by lowering the cost, but it's a tight budget, and I'm wondering if anyone can shave any more off the total, or improve the performance somehow? Or both...
And lastly, but very importantly, I need to somehow get my files off my old 60GB HDD, so I'm hoping to fit both this one, and the new HDD I'll buy, into my rig and copy them across. The old HDD is a Seagate Barracuda ATA IV 60GB Model ST360021A - will I be able to fit them both and use them both in the new PC? If so great, I'll start reading up on the master-slave process, if not, how else can I get the files off as I my Alienware will not boot?
Thanks very much for reading
Chris
And I'll be very glad to improve on the 2 USB ports! This will be mainly used for gaming, or maintaining my website, but seeing as I did that easily for years on the Alienware that won't be a problem for this one.Now obviously I've taken a hit performance-wise by lowering the cost, but it's a tight budget, and I'm wondering if anyone can shave any more off the total, or improve the performance somehow? Or both...
Chris
