Evening everyone, I've been browsing these forums for the last couple days and finally decided to register albeit because i could do with some assistance.
I need a little advice on a new gaming rig I'm hoping to build in the next couple of weeks. My budget is £1300, I would like to overclock and I'd prefer not to have to update it for at least 2 years if possible.
I haven't owned a PC for about 3 years now and have had to make do with a laptop, I'm not computer illiterate, just a bit out the loop on current PC hardware. I've spent the weekend doing as much research as possible and came up with the following gear to use for the new PC.
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Quad Pro Q6600 "Energy Efficient 95W Edition" 2.40GHz (1066FSB) - Retail
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
OCZ StealthXStream 600w Silent SLI Ready ATX2 Power Supply
Zalman CNPS9700-LED Aero Flower (Socket AM2/939/754/775) CPU Cooler
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache - OEM
Microsoft Windows Vista Home Basic 32-Bit Edition DVD - OEM - 1Pk
Creative Inspire T3100 2.1 Speakers - Retail
Logitech Deluxe Keyboard (Black) - OEM
Microsoft Basic Optical Mouse - Retail
Antec Nine Hundred Ultimate Gaming Case
NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM
Sony DDU-1615 DVD-ROM (Black) - OEM
Samsung SM-206BW 20" Widescreen LCD Monitor - Glossy Black
Arctic Silver 5 Thermal Compound (3.5g)
Total : £1,298.13
With the OEM products i realize some of them are drive only, so will the motherboard and case have the necessary cables and screws to get them connected and working? Also The OCUK 8800 GTX, does that have everything i need, drivers, cables, etc?
How far can i overclock the Q6600 G0, taking the ram, motherboard and zalman 9700 into consideration? Or perhaps should I avoid the new Q6600 and just go for the E6850?
Any advice is very welcome and i look forward to reading your replies.
By the looks of things the Atec nine hundred is going to let in a lot of dust, any advice on how to prevent this or perhaps an alternative case?
Will the power supply be enough for this setup? I'm planning on adding a second 8800 GTX in about a year or two, so is it wise to get a larger PSU now, or should i wait until then when everything is a lot cheaper?
I'm probably not going to run my games at a res higher than 1680x1050 (max resolution of the screen) and i know its a waste to get a GTX but i want this thing to be as "future proof" as possible. So if you have a strong argument not to get a GTX I'm all ears.
Total : £1,298.13
