- 26 Jun 2008
- London
Hi all, thought I'd introduce myself. Been lurking on these forums for the past few months, but just got round to registering (a few days ago).
Anyway, my first post is a spec help one
so please be gentle. Last time I built my PC was a few years ago (Barton 2500+ IIRC), so completely out of the loop as to what's the latest hardware.
I am planning to build a HTPC which will be connected to my 1080p capable LCD TV in the living room.
Main criteria:
1. Quiet, Cool and Energy Efficient - The pc will be left powered on almost 24x7, so it definitely needs to be low power
I would actually prefer if there was a way of passive cooling the cpu/gfx/mobo chipset, but not at the cost of performance, as 1080p playback can be quite demanding.
2. Decent case as it will go on the TV rack next to my AV gear. I've used Antec's in the past, which were pretty good. Not sure if they are still the ones to go for ??
3. A lot of usenet downloading intended, so hard disk needs to be reliable, and most importantly run silent, even while in constant use (Looking at around 750GB - 1TB for hdd space).
4. No gaming or overclocking of any sort, so decent onboard graphics will do, as long as there is some support for intensive video decoding to relieve the pressure on the CPU.
I'm planning to connect it to the TV straight via HDMI for minimum hassle. Is there a way I can pipe the PC audio to the TV speakers as well, so I don't have to connect separate speakers to the PC ?
Sorry for the long post, but I've tried to include as much info as possible. Budget is around £600, though this is not set in stone and can go up if there is a definite need for it. I just need the basic unit, without any peripherals or OS, which should help keep the cost down.
Any advice appreciated
so please be gentle. Last time I built my PC was a few years ago (Barton 2500+ IIRC), so completely out of the loop as to what's the latest hardware.I am planning to build a HTPC which will be connected to my 1080p capable LCD TV in the living room.
Main criteria:
I would actually prefer if there was a way of passive cooling the cpu/gfx/mobo chipset, but not at the cost of performance, as 1080p playback can be quite demanding.2. Decent case as it will go on the TV rack next to my AV gear. I've used Antec's in the past, which were pretty good. Not sure if they are still the ones to go for ??
