First Ryzen Build for a Friend
5 Oct 2009
Spalding, Lincs
Hi all,
I am building a new PC for a friend to replace his Q6600 powered machine. I have come up with the following spec:
My basket at Overclockers UK:
Total: £691.39
(includes shipping: £0.00)
This PC will be used for some light video editing, like Go-Pro footage etc and general internet use. The Ryzen 5 seems a good fit with 6 cores for video editing. Just want to make sure that everything is compatible and nothing is missing. This wont be used for any kind of gaming at all.
As above
Also the Asus micro only has 2 DIMM slots the gigabyte has 4 (could be useful) and VRM heatsinks (not vital).
I've also added a SATA SSD it's cheaper and little performance difference and enables you to get a better PSU - although you may need the extra for a GFX card :)
Thanks guys, I had completely overlooked the lack of iGPU, so glad I asked!
Taking in the suggestions here's a revised spec:
Total: £704.78
I have had to change the ram from 16GB to 8GB to keep within budget, but the ram was overkill anyway, and something easily added in future.
