Caporegime
- 13 May 2003
- Warwickshire
Hello guys
I want to downsize my PC footprint into laptop + discreet living room, so I've been speccing up a PC that will hopefully suit my needs for a gaming upgrade as well as an HTPC.
Could you take a look at the following:
Silverstone Sugo SG06B, Black, Mini ITX Case, Aluminum with 300W 80+ PSU £65.97 £77.51
Gigabyte GA-H55N-USB3, Intel H55 Express, 1156, DDR3 1666(OC), SATA 3Gb/s, Mini ITX, On Board VGA £69.55 £81.72
Intel i5 760, S1156, Lynnfield Quad Core, 2.8 GHz, 8MB Cache, Core Ratio 21x, 95W, Retail £124.95 £146.82
4GB (2x2GB) Corsair XMS3 Classic, DDR3 PC3-10666 (1333) Non-ECC Unbuffered, CAS 9-9-9-24, 1.50V £53.77 £63.18
120GB OCZ Technology Vertex 2E, 2.5" Sandforce SSD, MLC-Flash , Read 285MB/s, Write 275MB/s £159.49 £187.40
1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ, OEM £35.93 £42.22
1GB XFX HD 5850 Black, PCI-E 2.0(x16), 4500MHz GDDR5, GPU 765MHz, 1440 Cores, DP/ 2x DL DVI-I/ HDMI £179.58 £211.01
Logitech diNovo Mini Bluetooth Handheld Keyboard £67.50 £79.31
Net Total £756.74
Carriage £0.00
VAT £132.43
Total £889.17
...and let me know if you'd change anything? I'll be doing everything from this; watching HD video, listening to music, gaming, encoding, office work, browsing the internet...
For example, am I going overboard with the CPU do you think? Although it's not a cheap build I'd still like it to be bang-for-buck. Any glaring errors / omissions?
Many thanks.
Net Total £756.74
Carriage £0.00
VAT £132.43
Total £889.17
Many thanks.
