First SSD build - compatibility with this mobo?
26 Feb 2008
Looking at the GA-H77M-D3H as per my build thread
Does anyone know if I'd need to flash the bios at all for it to be compatible / any other known issues with this board?
Wouldn't usually bother me, but its a system for my Dad so minimum tinkering is a necessity. -- this may be irrelevant anyway, all I know is my experience of SSDs when they first emerged, where everyone had to flash to various dodgy new bios' on their mobos (new and old) to get the ******* things to install windows.
Failing knowledge on the gigabyte - what's about (in 1155) around the £80 mark that'll take an SSD no troubles? :D
Cheers guys
I should add that the SSD will be a 128gb Realssd M4.. Figured Crucial would be the most widely compatible -- unless anyone else can suggest otherwise?
