First steps into VR
6 Mar 2004
Hi all, I'm VR curious and looking for some advice, I've done some research to the point that I'm going round in loops so hopefully someone can nudge me in the right direction.
I've recently started sim racing at a pretty casual level and I’m interested to try VR as it sounds fun. That being said I've not used VR much except for a few times at work but that was more novelty than intensive use so there’s a chance that I won’t get on with it. Games are typically AMS2, Assetto Corsa, and sometimes the F1 games.
It looks like the mainstream option is the quest 3 however I’m flip flopping between the 3 or the 3s as in a quick search the 3s can be found quite a bit cheaper on the 2nd hand market (~£80-100). On top of this my PC options aren’t the most powerful, I have the choice of:
Desktop: ryzen 5600, 16GB ram, RTX 2060
Laptop: ryzen 5600H, 16GB ram, RTX 3060
So not much to pick between the two.
Part of me thinks just get a quest 3 and have a go, worst case is that I don’t like it and have to sell it on. Well, worst case for my bank balance is that I decide to spend out on a GPU upgrade.
On the flip side I could go with a 3s for less outlay and potentially have a better match for my slightly aging systems.
Dumb question, is there any benefit to going for a 3s to compliment a less powerful system?
Any help appreciated!
I'd always steer anyone who asks that question towards the Quest 3 purely because the pancake lenses/optics on the Quest 3 are so much clearer, with a larger sweet spot, than the fresnel ones on the Quest 3S. IMO that alone justifies the extra cost.
Yes that tallies with the general advice I've seen, thank you. I guess one thing that I don't have a feel for is whether I'm just going to have a terrible time due to the age of my sysems, the GPUs in particlar. And then whether stepping down to the 3s would ease this at all? Accepting my lack of knowledge the answer may well be that the model of quest makes no difference?
IIRC the resolution of the 3S i slightly lower but I'd expect the performance difference when using PC VR would be negligible so I wouldn't let that influence your decision. Budget permitting Quest 3 is abolsutely the one to go for.
Quest 3 for sure its not really a debate imho, if budget is tight get a used one.
If the hobby grabs you then more GPU grunt in the future I'd always recommend to people to out spec their GPU ahead of a VR headset rather than the other way around.
Also the GPU and CPU you use for VR really depends on your use case. General VR gaming can get away with a mid-level GPU and CPU (Many games are quest ports or older ones with lower requirements), but if you're running heavily modded Skyrim, or flight and racing sims you really need a top end GPU. Even my 9950X3D + 5090FE struggles with some games, especially some VR mods of 2D games and can't max out flight and racing sims.
