First succesful OC
WKN
WKN
Permabanned
3 Dec 2011
Bristol
Okay so i just managed to get a OC on my i5 2500k to 4.6ghz no BSOD yet.
Edit: Just got BSOD so i raised vcore to 1.370
System spec in my sig, I used the same settings from this guy but i have memory on Auto and my Cpu voltage is at 1.365v
Does everything look okay?
What OC settings should i use for my ram? (Corsair 8GB Veangence 1600mhz)
Thanks
you don't need to use extreme LLC and no reason to use more than 100 percent CC. youll have a good chance of hitting 5ghz with that cooler. Ram settings i left on default.
What LLC should i use instead? And the 100% CC is that the setting i have at 130%?
Changing these two wouldn't that mess up my OC? and then i have to re do it all to maintain stability?
Thanks
Alright thanks mate il change that later, I've run intel burner 15 times on Very High. Then i switched it to maximum straight after and run it 20 times. Would you say this is stable enough for gaming?
