- 16 Sep 2011
I've been putting off buying for about half a year now (hence the large amount saved for the build) muddling along with my bastardBootcampingWindowsIntelMac that is starting to be a wee bit slow for HD rendering. I'm currently a student animator/vfx artist but this build is to last me through my last year at uni into freelance work. I'll want to run all the latest Autodesk and Adobe software, lots of particle simulation and raytracing (sexy!). Compositing with HD footage. Want to be as general as possible with my freelance work (cast a wide net and all that) so a nice all round machine would be great.
Main reason for putting off the build is that I'm woefully undereducated (emphasis on the 'derr'). I've got a computing A-level under my belt so I know my components but it's brands and compatibility that I'm struggling with.
Also do a lot of digital painting so looking at a large Intuos4 so really I've got around to spend £1780. If I've got money left over then I'd go for a dual monitor setup.
So what would you do with £1780 if you had those specification? and any advice would be very welcomed.
