First time build, advice/suggestions?
How Odd... hmm... :/
The Gene-z mATX appeals to me due to price, size and sound card... elsewhere it seems to be fairly comparable to the Extreme rev 3.0... Is there any particular problems the Gene-z would create?
Or any very good motherboards around 150 you'd recommend and would go well with the spec?
