First time build could use help and advice
9 Apr 2009
Hey all, recently attempted to upgrade my graphics card on my computer and it just didnt work, i think my core parts are a bit old. so decided to try building my own to fit the graphic card.
I've never built a pc from parts before, ive been through what OCUK has to offer and came up with the following.
i dont have much of a budget to work with about £450 :s
tell me what you think and what you think i could change bare in mind me meagre funds
also could you tell me if all the parts are compatible and what addition cables i will need :)
  • Asus TM-261 Case - Black/Silver
  • OCZ ModXStream Pro 400w Silent SLI Ready ATX2 Modular Power Supply
  • Asus M3A78-EM AMD 780G (Socket AM2+) PCI-Express DDR2 Motherboard
  • AMD Phenom II X4 Quad Core 920 2.8GHz (Socket AM2+)
  • Asus ATI Radeon HD 3650 Vcool Silent 512MB DDR2 TV-Out/Dual DVI/HDMI (AGP)
  • Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel
  • Western Digital Caviar Black 640GB SATA-II 32MB Cache - OEM
  • Samsung TS-H353B 16x DVD-ROM SATA
  • Akasa AK-876 CPU Cooler
i have the Radeon HD 3650 graphics card, and can get the RAM
will be running VISTA home premium 32-bit
would be greatful for your input
-Hollow-
