Hello there, as thread title says, I am going to be building my first full system from scratch, have always used either junk systems from what will be unnamed pc/electronics high street shop, or a prebuilt overclockers system from many years ago, while I am reasonable confident with the small stuff, this will be my first system so a little nervous, just wanted some input with the following items and some general advice for a novice really, It will be generally for gaming and (when I upgrade the gt1030) 4k media.
I do already have a CX750M psu that I picked from the bones of the local Maplin store when it went under for a great price, I will also be reusing my current graphics card for a couple of months so I don't need one for now. Does anything stick out in terms of compatibility to you guys and girls?
Seen some discussions about ram speeds but from what I can work out ram speeds for coffelake won't get much benefit above 2666mhz, Or atleast anything above that will be limited to 2666mhz without XMP so is it worth staying with the 3000mhz?
I am initially not going to be overclocking the CPU until I am more comfortable with starting from scratch, but down the line it is something I will look at hence the 8600k, as for cooling I don't think I will need more than the preinstalled case fans I think? I know I will need to add when I do look at overclocking the CPU and upgrading the GPU down the line?
Thanks for the help
edit, is it worth getting an ifixit kit or similar for this? aside from general screwdrivers I don't really have any other tools. budget wise I do have some wiggle room, but don't really want to be going above about a grand unless I have to.
My basket at Overclockers UK:
Thanks for the help
- 1 x Asrock Z370 Extreme 4 Intel Z370 (Socket 1151) DDR4 ATX Motherboard= £142.99
- 1 x Alpenfohn Brocken 3 CPU Cooler - 140mm= £42.95
- 1 x TeamGroup Dark Pro 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black/Grey (TDPGD416G30= £169.99
- 1 x Silverstone M.2 Heatsink - Black= £10.99
- 1 x Fractal Design Meshify C Midi Tower Case - Black Tempered Glass Window= £89.99
- 1 x Samsung 970 EVO Polaris 250GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive= £94.99
- 1 x Noctua NT-H1 Thermalpaste (2.5g)= £6.95
- 1 x Intel Core i5-8600K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £218.99
- 1 x Microsoft Windows 10 32/64-Bit (Creator Update Ver.)- USB Pen Drive - Retail (KW9-00478)= £104.99
- 1 x Seagate 3TB BarraCuda Internal Hard Drive (ST3000DM008)= £73.99
Total: £969.42 (includes shipping: £12.60)
