Hello everyone this is my first post after it took me about 10 times to sign up with the image verification thing!!
This is the first time I've looked into building my own nas. In fact it will be the first time I've custom built a pc. I'm planning for it to be a NAS but could one day replace my mac mini as a HTPC.
I'm planning to use unraid
I'd like it to run plex media server also now that there is a linux install for it.
So far here is my kit list:
case: http://www.chenbro.eu/corporatesite/products_detail.php?sku=159
motherboard, cpu, gpu: http://www.overclockers.co.uk/showproduct.php?prodid=MB-442-AS
ram: http://www.valueram.com/datasheets/KHX1333C7D3K2_4GX.pdf
hdd's probably start with a 2tb wd cavier green with unraid it allows you to add more on the fly.
Do those specs look compatible/ok?
I will be wanting to access files from osx and windows.
This motherboard combo uses 18w of power so it's quite low.
What would be a intel atom alternative for this?
I've been trying to look but struggling to find out power consumption details. It would need to have 4 sata ports or a pci e express slot to put a controller i guess?
Thanks.
Thanks.
