first time build, on a budget
25 Jun 2016
Hi, Im trying to put a gaming pc together for hopefully less than 300.
Just want to make sure im not missing anything and these parts are all compatible.
Gigabyte H110M-S2H Intel H110 (Socket 1151) DDR4 Micro ATX Motherboard
Intel Core i3-6100 3.70GHz (Skylake) Socket LGA1151 Processor - Retail
Kingston Fury Black 8GB (1x8GB) DDR4 PC4-17000C14 2133MHz Single Channel Module - Black (HX421C14FB2
Gainward GeForce GTX 750Ti Golden Sample 2048MB GDDR5 PCI-Express Graphics Card
Kingston 120GB SSDNow UV400 Drive SATA 6Gb/s 2.5" (7mm height) Solid State Hard Drive - (SUV400S37/1
I have a 350w psu, will that be enough to power this? Id appreciate any help or advice
the psu is old, says FSP group inc on it, not for gaming. I can get a decent one for cheap second hand though. was more concerned about the RAM, will any DDR4 RAM at 2133Mhz work with the H110 chipset motherboard?
350 be enough depending on model you choose, my system came with a 350w corsair and was powering my haswell i3 and a 750 non ti, suppose in the same way as yours apart from mine has a 1tb hdd and no ssd as mine started off as a prebuilt and my sig is what it is now.
However if you got enough to get a 400-450w then get that, my 520 seasonic is great, but I had a corsair 400w of some sort awhile back that's an old model Did well in an older gaming system I had at the time.
you must be going used for that level of kit for that price? I would look around of you going used as you can pick up some good i5 systems and other good level of kits.
What is the model number of that psu because FSP have made some awful ones in the past. Get a pair of ram sticks so you get the best performance out if it.
