Hi everyone - I am trying to put together a watercooling loop to cool my CPU and 2 GPUs.
I'll address what might be a popular question first - I'm not planning on buying a bigger case
(I know, it would probably make the layout more straightforward, but humour me...)
Here's the layout I'm planning - green squares represent a 90 degree angle being required, and blue represents a 45 degree angle being required. I hope it's clear why the angle is required but please ask if not.
I've revised the layout several times to try as much as possible to avoid 90s, this is about the minimum I can get it with the aesthetics I want. I purposefully put (what I thought was) a powerful pump so I have spare capacity to ensure the loop runs at an optimal speed.
Here are the parts I'm looking at using:
* XSPC Raystorm for CPU
* Watercool HeatKiller GPU-X Core LC for GPUs (backup alternative: EK Supreme HF Bridge edition)
* Watercool HTF4 140.3 radiator + feet + fan shroud (this is the external rad on top of the case)
* Alphacool NexXxos 120.1 radiator
* Aerocool Shark 140 fans (covered in another thread + comfortable with these)
* Alphacool VPP655 pump (D5 I believe?) and HF pump top
* Monsoon 3/8" 5/8" fittings
* Masterkleer or XSPC 3/8" 5/8" clear tubing
Less important parts (it seems these are more personal choice, but in case anyone is interested):
* Aquacomputer Aquabox 5 reservoir
* Aerocool Touch 1000 fan controller
* Aquacomputer inline temperature sensor for loop
(I know, it would probably make the layout more straightforward, but humour me...)Here's the layout I'm planning - green squares represent a 90 degree angle being required, and blue represents a 45 degree angle being required. I hope it's clear why the angle is required but please ask if not.
- I found it (out of stock) on one site though. I also found something else that might work - an XSPC one. It would sit in about the same amount of space as the pump/top I've got now, but push back further into the case (which is fine). The only thing is that because I want some fairly neat routing, I would still have to have that right angle at the top right (between CPU block and pump) otherwise the tubing would end up curving over the graphics cards. Decisions, decisions
