i am intending on attempting my first build with the following spec :-
AMD Phenom II X4 840 Socket AM3 3.2GHz 2MB Cache Retail Box Processor
Seagate ST31000528AS 1TB Hard Drive SATAII 7200rpm 32MB Cache
LiteOn IHAS124-19 24x DVD±RW DL & RAM SATA Optical Drive - OEM Black with Nero Essentials
Kingston DDR3 2GB 1333MHz i5 Memory Module CL9 1.5V
Asus HD 6850 Direct CU 1GB GDDR5 Dual DVI HDMI Display Port Out Graphics Card
Asus M4N68T-M LE V2 Socket AM3 DDR3 Geforce 7025 VGA Out 8 Channel Audio MATX Motherboard
CIT 750W Dual 12V Rail 12cm Fan PSU - 4x SATA 1x PCI-E
Speedlink 7.1 PCI Audio Card (inc optical cable)
Tenda Wireless-N300 PCI Adapter
Casecom Black/Silver Mid Tower Case - No PSU - Front Blue LED 120mm Fan - With Side Window
however i feel i may need a better motherboard and/or case what do you guys think ??
my budget is about £450 !!! would love to spend less !! the spec above comes in at under £450 although i know there is no OS on there i can always sort that out within time !!
so please please help me out !!
thanks wayne
thanks wayne
