This is going to be a first time build for me. I plan to do heavy multitasking and some games - esp flight sims.
I will be overclocking for the first time, hopefully to around 3ghz (e.g. beyond the level of the E6700).
I plan to upgrade to a more powerful graphics card when the DX10 cards are released - this choice is just a stop gap measure.
Can anyone give me some help in understanding:-
- Is E6600 the right choice? I originally planned to go for the E6700 but I am reading that it is not good value.
- Is this motherboard a good choice? I am really slanting towards an ASUS P5W now as I have heard a lot of bad stories about ram nightmares with the Gigabyte board.
- Have I got my memory choice right?
- As a newbie to build & overclock (but pretty savvy with PC's and tech stuff in general) how difficult is it going to be for me to build & overclock and end up with a stable system? I dont want to overclock for the fun of it, just for a performance boost but i want a stable system that will last me 2-3 years.
- Will this cooler & case be good choices in terms of cooling and also keeping noise down? I am leaning towards maybe a Coolermaster Praetorian in stead as it seems to have better cooling and a bit more space.
- Will I notice the difference the Raptor makes, or should I substitute it for a Seagate?
- Is it worth getting a sound card to reduce CPU cycles?
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
Gigabyte GA_965P_DQ6 (Socket 775) PCI-Express DDR2 Motherboard (MB-058-GI)
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB) (MY-108-CS)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
EVGA GeForce 7600 GT KO 256MB GDDR3 HDTV-Out/Dual DVI (PCI-Express) - Retail (GX-005-EA)
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache - OEM (HD-069-WD)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
Coolermaster Wave Master - Black (No PSU) (CA-047-CM)
Antec NeoHE 550W Modular ATX2.0 PSU (CA-046-AN)
Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Black (HD-002-MI)
NEC ND4571 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Silver) - OEM (CD-032-NE)
Your help appreciated!
