- 17 Mar 2006
- Perth
I've decided, after reading these forums for the past few months, to build a new PC for myself. My current system is over 2 years old now, and showing its age. I was initially unsure about whether to build myself, since I've never done it before, but reading the forums has given me the confidence to do so.
I'm not an overclocker, so that's influenced a couple of my hardware choices, but here's what I've come up with over the past few weeks:
Potential Spec.
(System will be for gaming, web browsing, listening to music and some video editing)
CPU: Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Motherboard: Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
Memory: Corsair 2GB DDR2 Value Select PC4200 Dual Channel Kit (2x1GB)
Graphics Card: HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail
Disk Drive 1: Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM
Disk Drive 2: Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM
Disk Drive 3: OcUK Value Floppy Drive - Black
DVD-ROM: Samsung SH-D162 DVD-ROM (Black) - OEM
DVD-Writer: Samsung SH-W163 16x16 DVD±RW Serial ATA Dual Layer ReWriter (Black)
CPU Cooler: Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775)
Case: Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU)
PSU: Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU
OS: Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk
How does that look - everything compatible? I've chosen most of the things from reading recommendations on the forum (eg. PC7+, the 7200.10), but I am still a little unsure about a couple of things.
I was originally going to go for faster RAM, but after reading this:
http://www.madshrimps.be/?action=getarticle&number=4&artpage=1965&articID=472 it seems the cheaper PC4200 should be fine for me.
However, the main component I'm unsure on is the Motherboard. I originally looked at the "Intel DP965LT 965 (Socket 775)" then at the "MSI 965P NEO (Socket 775)". Is the DS3 a better choice than either of these boards? Or should I go for something else?
Also, is the floppy drive necessary? I've seen some people say you need it to install SATA drivers when setting up the XP installation, but others say they are fairly pointless.
I was also looking at the Belkin 4-Socket SurgeMaster - how useful would this be, and what sort of protection will it offer? I've never had any PC problems with powercuts or anything before and I don't live in an area where powercuts are common, but would it be a wise investment to protect my equipment?
Like I said, I've never built a PC myself before; I've installed a PCI TV card, and swapped hard drives between machines; but not built from scratch. Any important tips to keep in mind?
I've read some building guides recommended on here, and I think I'm now more worried about setting up the BIOS and installing Windows than the actual building! Is the system setup all fairly simple?
I think I've read too many things, and I'm probably just confusing myself unnecessarily! But obviously I want to make sure everything will work out OK, especially since it's my first time. Any advice will be appreciated
Oh, and apologies for the long post!
Potential Spec.
