I could really do with some advice here.
I have been building nothing but Intel PCs for years but the current Ryzen CPUs look awesome so I thought I'd give it a go. First time with an MSI board too but I like the spec of this one compared to my usual favourites.
Here's my main components:
AMD 3950x
MSI MEG x570 Unify
16GB Corsair 3200 DDR4 (Ryzen Optimised)
MSI GT 1030 GPU
Samsung 970 Pro 1TB M2 SSD
Corsair AX650 PSU
Put everything together and fired up for the first time and it was slow to post but got there in the end. Boot from USB to install Windows and after install it got stuck in a boot loop. I ran the install again and cleared all the partitions on the SSD. This time it installed fine - Windows updates applied and x570 chipset drivers installed......happy days.
I then entered the bios to check some basic stuff and I noticed that the memory was not set to 3200 so I enabled A-XMP and restarted. Now it won't post at all. I tried the clear CMOS button on the back of the board a few times but the problem persists. All fans spin (including the chipset fan) and all the usual lights for power etc on the case are on.
I was going to try the CMOS jumper but there isn't one included - just the bare pins on the motherboard. Next thought was to pull the battery for a few minutes but that is under the GPU and I ran out of time.
Sat at work this morning trying to decide what to try tonight. I can't believe turning on XMP would kill it, and why on earth doesn't the CMOS reset button work?
I guess my only option is try the USB flash method using the other button on the board but I'm nervous that if this doesn't work I may make the problem worse and not be able to return the board.
Any suggestions from someone with a similar setup?
AMD 3950x
MSI MEG x570 Unify
MSI GT 1030 GPU
Corsair AX650 PSU
