first time HTPC
26 May 2008
Hey all I'm looking to get myself a little HTPC.
Ideally I'd be looking for something that can output high def movies to my 26" sony bravia, soon to be 32". Ideally at 1080p.
I've never really built a HTPC before so bit confused and got a few questions,
1. is it better to buy pre-puilt or custom build one?
2. can i use an old e7200 core 2 duo if going for custom?
3. is having a drive essential, Ideally I'd be looking to rip blu-rays onto a HDD for easy viewing.
Any recomendations? or advice would be greatly appreciated.
Custom is always best - firstly decide on what case you want then build everything around it. I've got a antec fusion case, with an i3 540 and 4 gigabyte ram M-Atx motherboard and 2x2tb storage.
Your case will decide whether you want m-atx or i-tx then either intel or amd just depends on budget.
No, decide what you want it to do and buy the case based on that ;).
I've currently got the following from my old system,
CPU: Intel Core 2 duo e7200,
PSU: Corsair 550w.
Memory : 2gb Generic ddr2 ram.
also have a Dual layer DVD-RW drive, tho could possibly get a blu-ray drive.
I'll need a case, motherboard and a descrete GPU for HD video output.
Any good socket 775 mini-itx boards? really like the lian li PC-Q07B but not sure if i'll be able to get a board with a PCI-E slot.
If not I may go for a fusion based setup, this one looks quite good Sapphire itx fusion board
