Good luck!
Superb!
This is the setup I want!
Excellent!
I found that the 8 pin lead on that PSU for my case was OK, but not long enough to make tidy via cable management.
Is there a hole in your case near the connector for it? Otherwise have you considered using a dremel to create a hole or hole(s) to make it reach OK behind the backplate?
It's such a great feeling when it works!Well done mate!
Get some Blu-Tack Glu Dots to mount your SSD in one of the normal bays if it has the removable mounting things. Otherwise think about mounting it on the backplate with them?
Do I believe the BIOS or Real Temp??Is that OK?
i like your mobo, cpu and psu - the case, not so much
anyway, my bios always reports numbers about 10 degrees higher than what it tells me in windows, so i dont believe it![]()
You've found the holy grail - even temperature across all cores!
What TIM application method did you use?
Just ordered a 128GB SSD and Noctua NH-C14!
Ouch! Yeah I'm currently just running my SSD and an external USB2 drive.
I'm thinking that I don't want a mechanical drive now seeing as the system is so quiet (apart from the optical drive which is a bit noisy for my liking). I might just get another 256GB for apps etc and continue to use an external for documents and stuff.
When i installed this i found it a lot easier if you removed the top fan first. Look forward to seeing this in place
I'm currently planning a similar build right now- recieved my Antec 300 this morning, and just ordered my RAM. How much have you spent on this build? (minus LCD, and other peripherals).
Cheers
