I've built a few PCs before but this is the first time I've modded a case, cables etc.
I'm going to be using hardware I have at the moment until Haswell makes its appearance. So here is what I already had:
Intel i5 2500K
Gigabyte mItx
8GB Kinston Ram
Add to that a new Prodigy and a Seasonic X650, plus other bits in the next few weeks.
I started by removing the piece of metal that was stopping the large modular power supply from fitting properly. I only have a hacksaw (no dremel yet) so I did the best I could. Lined the cut with rubber C channel and it looks pretty good.
Then I marked how long I wanted the 4 pin cpu power cable. De-pinned the connects and got cutting, stripping and crimping new pins on. I'm using MDPC sleeve and shrink in white. It's far from perfect but for a first try its not too bad.
One thing that I would change next time is to start completely from fresh with new white cables. I started wrapping the cables in yellow tape but that just got tedious so I gave up. The effort that it took to do what I did though I might as well have started from scratch using white cables. Also did the 24pin a little too short, it will make it hard at the end to get it really tidy.
I'm going to use 2 strips of Alchemy blue LEDS as lighting and have a button on the rear as a switch for them. (I'm going to be watching films on it so dont always want the lights on). For this I drilled a 16mm hole in the back.
Now I'm waiting for the LEDs, switch and Corsair AF120s to arrive before going any further. Dont hate too much, it is my first attempt!!
Intel i5 2500K
Gigabyte mItx
8GB Kinston Ram
, them dremels can be a right pain and are tedious to work with for sure.
