- 11 Mar 2007
Hi,
My system has been running now for just over 2 weeks without problem.
So now I’m going to try and overclock it.
Decided to run Orthos to make sure the system is stable before I overclock & got this message,
“More than one CPU detected, You should run two copies of SP2004 simultaneously.”
I ran another copy, set CPU: 0 on the first one & set CPU: 1 on the second, then started both with Blend test.
The first copy (CPU: 0) started to run through the tests but the second copy (CPU: 1)
Just stayed on test 1 with PAGING showing in red.
Left them running for 15mins then stopped the first copy, no errors or warnings,
Then the second copy started to go through the tests, so left that for 15mins and stopped it, no errors or warnings.
Do I need to run 2 copies at the same time, or just 1 with Any CPU selected?
I’ve read through the posts on here about overclocking, but need the wisdom of you kind gents to get me to 3GHz.
Cheers,
Allan.
*I’ll get me coat*.
Cheers,
Allan.
*I’ll get me coat*.
