Hi everyone
this is the first time I've tried to overclock anything before
so really just asking for pointers and advice.
I overclocked my 1090T to 3.8GHz and it was stable after ~15mins on
Prime95. All I really did was up the voltage to 1.35v and put the multiplier to
19.
I am using a corsair H70 for cooling and core temp reports 17-20C idle at
stock speeds and a few degrees higher idle when at 3.8GHz. While running
Prime95 it went to 43C.
I know I need to run Prime95 for longer but I'm not really sure what to do
next. 4GHz is my goal but I've read that from 3.8 upwards it can be a little
trickier to keep stable.
Any help is appreciated
Here are some screenies for you:
19.
