- 28 Dec 2011
I have finally decided to have a go at overclocking im going to follow the beginners guide on here hopefully. Before i do i have a few questions.
First off all my setup is in my sig.
I checked my settings in bios everything was at stock so i want to ask
the CPU Vcore was1.152v and Dram voltage was 1.500v what sort of overlock would i get sticking with this voltage or is this just dependent on the chip? and the Dram voltage would i need to increase to get 1600mhz as currently its at 1333mhz?
and my second question is in bios and in speedfan whilst using prime95 it showed one of the systems fans only running at 752rpm i didnt think i had a fan that was below 1000rpm minimum in my system so this i confused me alittle as i know that they give or take10% which i figured would be 900rpm-1100rpm on a 1000rpm fan could this be because im using http://www.overclockers.co.uk/showproduct.php?prodid=CB-071-AK&groupid=1929&catid=1979&subcat= ?
at stock and after running prime small fts test for 40mins my max temp was 60c on lowest core and 67c on highest so is it worth trying to overclock or will the temps just be too high?
