First time overclocking GTX 780 under water
1 Aug 2012
Stoke-On-Trent
Hey guys, I've overclocked my card a little bit but i'd like to get more out of it.
I think it may be time i unlock the voltage on this and give it a shot.
I'm using MSI Afterburner at the moment as i feel comfortable with it.
What's the best method i can apply to my card.
In terms of how much voltage i should be applying etc.
Any help is very much appreciated.
Thanks
Voltage should show at 15 but isn't, Any good?
Have a look here and here.
A skyn3t modified BIOS would be a good place to start as it gives you more overclocking headroom in a number of areas. I ended up modifying my own BIOS using KeplerBiosTweaker and Svet's VBIOS Tuner so my OC settings are the BIOS defaults and I don't need Afterburner / PrecisionX running in the background applying them for me.
I would recommend looking at BIOS modding and making the most of what this brings to the table before going down the overvolting route.
/Edit: Just re-read your post and maybe you're just after some basic how to overclock tips so the above may be a bit overboard, though useful to you at a later date.
