- 24 Apr 2013
Hey
Im planning on overclcoking my i5 4670k and when i watched this video of linus tech tips he says that you should put your cpu multiplier to 46 on all cores ect. and see if the PC boots up ( Linus starts talking about it at the "Finishing" part ), is that a good thing to do because im really not sure whenever starting on a overclock that high is safe ?
Here is the video:
My system:
Asus Z87- A
i5 4670k
Noctua D14 CPU cooler (stock fans)
corsair vengeance LP 1600mhz
Asus DirectCUII 780 ( running at stock )
WD 1TB blue
Corsair 750RM PSU
Coolermaster 690 III ( Fans: Megaflow red LED fan 200mm, 120mm fan that came with the case at the back - dont know the name )
And could you guys give me any advice with what do do if I run into issues such as when the PC does not boot up, what would I have to do etc ?
I downloaded some testing software : Prime 95, Intel Burn test, AIDA64 Extreme, Cinebench, CPUID CPU-Z, CPUID HWMonitor and I also have 3DMark full version that I got on steam
As I said this is my first time overclocking and I want to make sure that everything goes well
Thank you
Here is the video:
My system:
Asus Z87- A
i5 4670k
WD 1TB blue
Corsair 750RM PSU
Thank you
... some motherboards would adjust the volts up automatically tho so watch this ...well did in my day overclocking
